Help ! Outer CV boot rempacement
(In Topic #147961)
I've got a problem, I'm afraid, I can't seem to remove the outer CV joint to replace the boot. The Haynes manual says there are older models with a circlip, and later models which nees 'a sharptap' with a wooden mallet to remove. I can't see a circlip, so I'm guessing it's the later model ('79 diesel). I also can't remove the driveshaft for lack of a 12 sided bit in my socket set. I'll buy a 12-sided bit on Monday and remove the shaft (on my cabriolet there are hex screws on the driveshafts) and replace the screws with hex screws, but I still need to remove one of the CV joints to change the boot.
Here's the kit I've got:
And here's how far I've got:
Do I simply bang it with a hammer to remove it? Where shouls I hit it, and how hard?
Any ideas gratefully accepted, as usual.
Robin
VW Golf 1500D 5-door 1978 - was daily (wet)
VW Golf 1800 cabriolet 1980 - daily (dry)
Bedford CF Trailblazer 1978 - camper
Bedford CF 350 Flatbed 1976 - fun/work
Mercedes W108 280s 1970 - dusty and forgotten
Mercedes S123 200T 1983 - to be renovated
Mercedes C124 1989 - Winter Beater
BMW E21 1976/82 - dusty but not forgotten
Twingo 2004 (not my fault, somebody gave it to me!)
Twitter Manager
:mrgreen:
The outer joint does simply knock off, its held on by the black U-shaped clip in your photo next to the copper coloured circlips. The clip is on the shaft 'inside' the CV joint. A sharp blow has the joint compress the clip and drop off the shaft. Its not that strong as when on the car the joints can't go anywhere beening trapped between the gearbox and the hub.
Robin
You can see the circlip in a recess in the photo. It was easier to remove the whole driveshaft (after buying the correct tool) and remove the CV joint onthe bench.
I reassembled with new bolts with a hex fitting, to make it easier to remove next time.
Thanks for the help,
Robin
just the info I need.
it does make the job easier if you can remove the shaft from the car but it is possible with it still attached but there isn't much room to work.
https://www.youtube.com/watch?v=yWodwx7VWFI
My Haynes manual says that the models till mid 80 have the circlip and from mid 80 onward you have to tap them of (like this guys does)
