oil pressure light and buzzer
(In Topic #198452)
1983 1.5 carb around 1900rpm to 2200 rpm oil light/buzzer keeps going off. I take my foot of the pedal when it comes on and then put it straight back on which then clears it until I get back to this rev range? I've tried both blue and brown pressure switches and I'm running the white one on the oil filter housing.
I've change both the high and low pressure switches
New oil filter and oil
I took the sump off and cleaned the pickup
when the car is at its running temperature there is no oil light at tick over or above 2200rpm. Really got me stumped!
It's either there is low oil pressure if so fit a new pump or faulty instruments buzzer I guess the senders are OK as they are new, did it do it before you changed the senders?
