golf 89 clipper cabriolet 1.8 8v conversion to ABF advice?
(In Topic #198351)
many thanks.
Last edit: by Steve Foulis
fueling wise can use off the shelf bits from later cab/rocco plus gti main pump, then rubber or braided fuel lines or try mk2/3/polo plastic ones they should be a close fit
need to add a power pin for the fuel pump(s) to the rear harness, either fit a gti cabrio loom or get the guy doing your engien loom to do you a pin with 2 wires off it, a male spade for the lambda power to plug in and another tail for you to splice your pump power. or remove your whoel rear loom and send that to him to add the pump power in.
any wiring guy who has a clue can do this for you, if they dont know what you're on about or struggle to understand ask someone else
