Hellos, i joined because my cars broke ;)
(In Topic #198374)
So, I've landed here.. hello
The story is, I have an '83 Golf MK1 Campaign that I have advertised for sale. Only I didn't realise there was a fault with the lights until someone came to look at it (I'd only used it in daylight).
When the headlights are turned on, the rev counter and clock go off. Moving the dash dimmer thingy makes them work a bit (the clock is dim and the rev counter isn't reading high enough).
Does anyone have ideas where to look? A wiring diagram would be really helpful too
1.Firstly check the small earthing wire that goes to the back corner of the engine rocker cover, make sure the wire isn't broken.
2. Try and take out the instrument binnacle, or at least move it enough to get your hands behind it and press the mani wiring connector into place, if I remember correctly it is in the bottom right hand corner and about a third of the width of the cluster.
If it's the back lighting it could be the dimmer part of the headlight switch, a new switch would sort it.
If the gauges themselves stop working it could be an earthing issue.
I had a look and can't see any earth connection on the back of the engine. Can someone tell me exactly where it is, or show me a photo please?
Hairyarse said
Welcome Kez. When you say the rev counter and clock go off, do you mean the gauges themselves or just the back lighting?
The rev counter stops working. i.e. it stays at 0. If I adjust the dimmer, it picks up a bit, but not much (idle shows as about 200rpm)
Kez said
Thank you for the replies people.
Have a look at this post and see if it helps
View topic: Rocker Cover Earth Issues - The Mk1 Golf Owners Club
It's fixed
Thank you so much
mark1gls said
Was it a broken earth wire to the rocker cover?
Yes, it had snapped off and was hanging down by the gearbox. I would never have found it down there without the photos. Couldn't even see where it broke off from, so i just added a bit of wire and a fresh connected, then bolted that onto the rocker cover.
All working fine now
