1.8 GTi running unevenly
(In Topic #196288)
Does anybody know what this could be?
how old and miles on the ht leads, spark plugs, dissy cap, rotor arm, air filter, fuel filter?
Do you hear a pinking noise under acceleration in a high gear?
Even if you did have the timing changed the DX engine runs it best on super unleaded, I tried normal unleaded and played with the timing but I could not get the car to run right and the power did feel a little down.
Have a look at the spark plugs and see what colour they are.
How old is the dissy cap and rotor arm, pop it off and have a look inside to check the condition of the contacts.
Not sure about dizzy cap and rotor arm. Don't think it's been changed in the 3 years I have owned it.
Be careful removing the ht leads from the dissy cap as its easy to break the connection on the ht lead when removing them, I've done it before and had to buy some new leads, just make sure you get the right type of cap as there is a couple to choose from, one with pins to grip the ht lead connection (later cars) and one without (early cars)
more info here.
http://www.vwspares.co.uk/g1electrical.php
mark1gls said
I would fit a new dissy cap and rotor arm see if that makes any differeance then once most of the fuel is gone try running on super unleaded and see if that makes any differance.
more info here.
Thanks M
Thanks Mark, much appreciated. Is this a good supplier of parts then? It's a 1983 1.8 GTi, so I guess I need part no. VK106 then either EVL090 or EVL096? Should I get some points and condenser too, do you think?
David
Being an 1983 GTi I don't think your car will have points and a condenser as it should have electronic ignition?
Dissy cap with pins for the connection
http://www.eurocarparts.com/distributor-caps
Rotor arms, there is 2 types one has the rev limiter built into it and the other has no rev limiter you can use either of them but if you have the type with a limiter built in and you replace it with one with out you won't have a limiter but there is no real performance above 6,000 rpm so no point reving the car higher.
http://www.eurocarparts.com/rotor-arms
Dissy cap with pins
End of HT lead for dissy cap with pins
Dissy cap with out pins
Last edit: by mark1gls
Cap, rotor arm, leads and plugs were replaced 2 years ago when I had a service, but I am not sure of the quality as someone else did this for me
How many miles have you done in the last 2 years since they was fitted?
As they have only done 800 miles they should be fine.
Good excuse to use the car and use up the unleaded petrol in the tank and stick in some super unleaded, it may take a couple of tanks to get rid of all the normal unleaded.
Let us know how you get on and if no better then I would look at replacing the ignition bits (spark plugs, HT leads, dissy cap and rotor arm) for some better quality ones like Bosch stuff (the only stuff I use on mine as it's my daily drive). Then if no better after that I would be looking at timing marks the check the cambelt has been put on right then on to engine timing.
So still some more things to try…..
Once I have been for a run I will report back. Thanks for your help so far Mark
