Help - MOT fail on HC emissions - now fixed!
Life Member
LeeO is right, so long as you're booked in that's the requirement from the law. It doesn't dictate how far.
check everything else is ok first though, could be an air leak or some other issue causing both
on my digifant co was around 0.1-2% and HC were thru the roof! as soon as co corrected HC dropped right back
John I'm jumping in on Richards post but as you may remember.
I have a Digifant on mine, so what sort of CO emission should I be seeing to know all is well please?
Sorry to hear about this Rich!
Sent from my Mobile Phone.
rubjonny said
book spec is 1% +/- 0.5%, id rather see it 1-1.5% than less though
Thanks John!
Thank you everyone for your advice.
RichardHall said
Can't find any air leaks, old plug leads back on and I will ask garage to set CO2 at 1.5% and keep fingers crossed.
The 'old boy' at the garage opposite mine always tells me K-Jets on this age of GTI should be set for CO ideally 0.8-1.2 - I think the Autodata books say that too.
Anyway, need not have worried, when they tested it, C02 remained at 0.31 but HC just 13 instead of 1500. Replacing the ignition leads with the old ones must have done the trick, a lesson there -if it's been good enough for 32yrs dont fiddle! Anyway I supposed I ought to find somewhere to set the C02 a bit higher, but it does seem to run fine.
Back from MOT centre, on-line to tax it and then took out for a good run, smiling every mile.
Premium Yam Yam
Lee
2001 Zafira 1.8
2001 Zafira 1.8
Lee
2001 Zafira 1.8
2001 Zafira 1.8
AVS Car Parts - [The VW - Audi - Seat - Skoda Parts Specialist]
