1991 gti cabby fuel filter needed where
(In Topic #192607)
MANN Part number WK834/1
I use copper washers and replace all four some times the new filter comes with 1 which I use, one side is the same size as a sump plug washer and the other side are smaller. I use a pair of plumbers pliers to grip the filter and a ring spanner on the bolt doing up the connection making sure it's tight as there is alot of pressure in the fuel system.
http://www.ebay.co.uk/itm/250mm-10-PLUMBERS-WATERPUMP-WRENCH-PIPE-GRIP-PLIERS-WATER-PUMP-SLIM-JAW-UK-/111494383167?pt=UK_Hand_Tools_Equipment&hash=item19f595463f
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1988/p/car-parts/engine-parts/engine-parts1/sump-pans-and-sump-plug/?360440010&1&edd594f76125444b5c44fcc9d7e50d82b006f54f&000567
The other smaller ones the same size as with the fuel filter I can remember the size but last time I took the one I had with the filter to a local motor factors and they had a box with washers in and they just gave me a few for free which was a result!
