The Miami blue ABF fast road/track day project!
Matt
MK1CRAZY YAHOOOOO!!!!!
g60gerry said
hey you car looks very well sorted keep it up, just a question if you havent already been asked previously, what is your brake set up, as it seems you have a 23mm master cylinder ??
I was told its actually a 24mm cylinder of a leon cupra? there is no real reason iv got it just that it was the same price as the mk2 16v item.
iv only got a 256mm calliper setup from an astra GTE they are sharp and do work well but i suffer very bad fade on the track which hopefully new pads will sort out.
Nothing seems too look damaged either which is good, the rivets that hold the crown wheel to the diff were a right pain to get out!
I also made a bracket for the clutch master cylinder which turned out a lot easier than i thought
Then my secret weapon turned up!!
Matt
