Replacement rocker cover
(In Topic #189519)
Any alternatives to powder coating?
Thanks for any help
Apart from the two options you mention above.
Why not have it professionally painted in it's original black finish.
They would dip it in acid and treat it etc before painting it.
Just a thought and I would do mine like that if I could find someone in Vienna who does that kind of work at normal prices!
87cab_bb said
I was thinking like a g60 rocker cover with the vw logo on, if u know which one I'm talking about?! I don't know if something like that is possible at all? Looking under the bonnet today I've got a massive job on my hands, probs not as much as some I've seen but I don't have the equipment and time and space to be whipping my engine out for the weekend and sorting everything lol! Wish I could as I'd never be outta my imaginary garage messing with bits n bobs
You said, " Wish I could as I'd never be outta my imaginary garage messing with bits n bobs."
YOU and ME both mate.
Can't even take a bucket of warm water to mine to wash it.
As for polishing well, cordless tools at the weekend and hiding in a corner of a supermarket car park when there closed!
So I feel for you mate.
I cleaned mine and painted it with satin black enamel paint in a rattle can and it still looks good 3 years down the line. You can still buy new ones if you don't want to paint it.
Thanks again, g60 rocker cover hunting begins lol
straight fit with same gasket, though i woudl recommend you fit rubber gasket kit. you'll need to change all the studs for the rubber gasket for shoulderless ones.
AVS sell the conversion kit: (look in mk2 section if not in mk1 section)
AVS Car Parts - [The VW - Audi - Seat - Skoda Parts Specialist]
for catch tank its a case of find one u like with 2 outlets andmount it somewhere convenient, run pipe from rocker to 1 outlet and breather filter on the other outlet. I would keep the PCV valve on the rocker too if it comes with one looks a bit neater plus has handy outlet on it. mk3 have 2 outlets cap the front one and run the rear to the catch tank
the rocker may be taller not sure, if so it wont affect anything except the airbox fitment if you have a stock one as it hangs over the cover but with a bolt on one you'll have stacks of room. deflector is the same
oil level is low down in the sump, if you have it filled up right to the top of the head you have problems
Cool I'm going to look into the catch tank, good info!
Thanks again, you seem to be a source of unlimited knowledge
pics? sounds like a g40 cover if it has a hole on the front?
I see the small hole you mention it'll just be a blind hole no need to worry about blocking it. i did recall reading that its there to allow oil to drain out if you miss the oil filler hole but not sure about that one
one thing i forgot to mention you'll need the later plastic timing belt cover to fit it, this will mean changign the lower cover and the inner metal cover if your engien has the older metal belt cover
I've asked the guy if he has the oil breather bit but he hasn't replied as yet so I'll find that out in due course
Aww man, I have the later plastic cambelt cover, In my tidy up process I was hoping to change my cambelt cover for the better looking metal type! Oh well, you can't have everything can you! So there is no possible way of having both the metal cambelt cover and the nice g60 rocker cover?
I'm so gutted about that lol
87cab_bb said
The guy has got back to me and the oil breather part isn't included as he's using it on his own car lol! What can I do about this? He said he'll knock me a 5er off because of this, probs guna cost more than a 5er to rectify but it's a nice gesture lol
Did he say that in the advert or at any other time, apart from just now?
