Power Dropping on hills
(In Topic #189962)
Got a 83 gx auto 1.5 been running fine since iv had it, it's got a little oil leak on engine (asked my mechanic mate about it and said it's common) and a small fuel leak. The other day whilst on a motorway going up hill got to 70 and the power would drop out intermittently. I'd take my foot off the gas and then it would seem to be ok then at the next incline do the same. It seems to only do it on hills, but I'm also noticing that when on flat or down hill Seems to be less power.
My left front indicator has also just gone and when I replace the bulb it still wouldn't work not sure if it's related?
Any help appreciated thanks!
check the wiring from the indicator, it runs to a 2 pin plug make sure the terminals are all clean. i assume the rear one works ok on that side?
yes the rear indicator works but its flashing fast.
with the fuel iv been using regular petrol since iv had the car and its been fine up until the last couple days. Ill try get fuel leak sorted too and see if that helps the problem. thanks
