9a cooling issue
(In Topic #186065)
fan not kicking in
Keith
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=14913
if you suspect rad is blocked feel it at various points after the thermostat has been open for a few minutes, you should feel the rad gradually start to warm up from the hose side across to the thermoswitch side. if it stays stone cold around the thermoswitch when temp gets to around 3/4 on gauge and your thermostat is definitely open (bottom hose hot) then this suggests rad blockage
Hella rads are good quality so no need to worry there
