tappets.......
(In Topic #181707)
mIsChIeF mAnAgEd.... kind of
jellybelly said
Tappers can be louder on start up until a bit of oil gets pumped round
If they remain loud then it's worth checking the tolerance
they don't remain loud but I can still hear them when I accelerate, pardon my ignorance but what is the tolerance?
jellybelly said
The tappets are a shim and bucket design
The buckets are al the shame but you get different shim thicknesses
You meassure the clearance between the shim and the cam follower using feeler gauges
You then either replace the shim for a thicker one or thinner to te max/min require tolerances
ahhhh, cool. may as well get the cam belt changed at the same time then.
Last edit: by al roper
