High pressure k-jet fuel pump
(In Topic #178697)
Has anyone got any experience of using the Bosch high pressure fuel pump B261 205 413 01?
It looks like this could be a direct replacement for the original k-jet fuel pump, for an uprated engine.
From the spec on the Bosch web site, this should be able to supply 8 bar of fuel pressure (which should be enough for a TFSI conversion). http://www.bosch-motorsport.de/media/catalog_resources/Fuel_Pump_FP_200_Datasheet_51_en_2776426379pdf.pdf
Lhasa2008
oem pump spec at 5bar is listed as 128l/hr, the bosch 044 motorsport pump can supply 200l/hr at 5 bar, the other one supplies 200l/hr at 8 bar.
but I think you may be looking at the wrong pump
APR 2.0T FSI High Pressure Fuel Pump (HPFP)
rubjonny said
kjet system works at 5-6 bar at all times!
So from the info on that goapr link that would mean that the k-jet pump should be sufficient to supply fuel from the fuel tank on the low pressure side of the TFSI fuel injection.
Lhasa2008
How will the K-Jet pump be sufficient if it only puts out 5-6 BAR?
I'm currently building a TFSI K04 Mk1 using the QPENG kit and according to en from QPENG the standard K-Jet pump's are fine.
I'm waiting on a price for a 413 just in case.
you just need a low pressure pump to supply it, for this the kjet pump would be more than good enough if not way over-spec
How's this going? Have you a build thread?
Did you manage to sort the prob with the pipe from the turbo to the intercooler?
Lhasa2008
I have one here http://www.edition38.com/forums/index.php?showtopic=433883&hl=
I haven't went at that pipe yet but I have a few ideas, I'll be going at it before the end of the week hopefully.
Have you got any ideas for it?
I dont know what flow rates are required this isnt mentioned, if I could get a VDO/bosch/pierburg part number of a TFSI pump then I may be able to find that out.
I wonder if the kjet pump could be controlled by the TFIS pump controller? I imagine the stock TFSI pump is just a std 12v unit its just a case of will the kjet pump like being driven by a PWM signal or if it will pack in. you will need to fit the low pressure sender G410 so the ecu can control the fuel pump module as well, I'm not sure exactly where that is located so this may present an issue as well if its in the main feed line as I assume you will be running your own…
anyway in short a normal kjet pump will probably be ok, it depends what flow rate the high pressure pump needs under normal and cold/hot starting conditions. if relatively low then the kjet pump should be fine to deliver the 6.5bar of pressure required
i have a TFSI in my mk1 golf but seem to be going through fuel pumps cavitating like nothing else.
Currently using a external 6 bar fuel pump, goes from the tank, through a high flow filter, through the 6 bar pump, up to the standard mk5 golf filter with a 6.6 bar pressure relief valve, and then on to the engine hpfp. this is all squeezed into a rather small space just infront of the RH rear wheel.
the pump is supplied with a constant 12v, and the ecu is programmed to think the fuel pump is being supplied with 98% capability of the fuel pump at all times.
the car seems to take an age to create the required pressure on start, pump runs for 10 seconds when ignition turned on until it cuts out, and it can take over 10 turns of the key to prime the system to the required pressure.
i have replaced the fuel pump, and also the OEM fuel filter, incase the relief valves were failing. it seems odd to me that the system is loosing enough pressure over a few days to have to require many turns of the key to prime the system again.
i have replaced the fuel lines from he tank to the pump with I/D of 15mm as that is what the pump required the I/D of the hose to be.
the I/D of the hose from the pump to the engine is 10mm
could the fuel hose I/D be too large and so it isn't able to create enough pressure? i haven't had this issue before but it now seems to be one, which to me indicates something is breaking down or failing?
i am trying to think of a way to troubleshoot this further, any thoughts or information known about the required supply of fuel for a TFSI is greatly appreciated.
also any information about pump installation position also appreciated, its currently below the fuel tank outlet, so it is always supplied with fuel.
thank you
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=how-to_2%2Ffuel-tank-cleaning_3&kfs103=30
though even if the pot seals were gone it would only be an issue when cornering with low fuel it wouldnt cause the other symptoms you're having unless the pot was blocked up somehow.
perhaps the pump is starting to die, or maybe the non-return valve has failed (assuming its still in the pump and wasnt removed and a barbed banjo adaptor fitted in its place)
to fit a pump i9nside the tank you would need to break up and remove the swirl pot or fit a carb fuel tank. then drop a 84-on cabrio & scirocco or g40 shape polo lifter pump in, then fit an external swirl pot between it and the fuel pump. though by the sounds of it you may not have the room to do so…
As a last resort i think i may look at using the spare wheel well for an external fuel tank, and have a lifter pump to take fuel up to the external tank and use that as a make shift swirl pot, seems to be the most cost effective and reliable solution i can come up with!
thanks for your help
