So my gear stick just went through the floor :/
(In Topic #177583)
mIsChIeF mAnAgEd.... kind of
However I remember years back mine did this and the problem was the circlip no 28 on the drawing had come loose and moved up the gearstick.
Hope you sort it
Hairyarse said
Can't help with the last question as it's been ages since looked at mine!
Hope you sort it
cheers andy I will go to the garage and take a look later to see if that circlip is still in its place… does anyone know where I can get the rubber boot that goes at the bottom of the gear linkage with the circle cap in it… gsf don't do them and nor do heritage and crazy quiffs is showing out of stock
Maybe one just to keep an eye out for. I guess as you've pushed your gearstick through it the rubber is ok but the sealing disc is missing?
Hairyarse said
Had a look around and can't see one on the mainstream sites. Looking back I got mine from ebay new for about £7 so was lucky.
Unfortunately not fella the sealing disk is fine but the rubber boot is absolutely knackered
