consul - ganuge wiring
(In Topic #148019)
I own a 87 cabrio that I own last moth
I have the three vdo gauges in that consul but all the wiring was cut off
Where I supposed to install each one of them?
1. VOLT
2. BAR (???) WHAT IS THAT ??
3.oil cels
wher is the correct point in the engine ?
Uri
bar is oil pressure you will need the right sender unit for the engine
oil cels is oil temp you may already have the sender if its a gti
try here for wiring
VDO Performance Instruments
But no, this is not GTI, this is a GL 1987, cabrio, with engine RE (carburetor )
The gauges are original - so all the sender supposed to be in that car - I just don't know where to look ?
uri
Bad luck to us - the wirers was also cut off - unbelievable…..
So we have two cars with the same questions
The volt meter can run from any ignition feed from the battery.
But you may not have the senders on the engines, you have two cars that have non-functioning gauges, perhaps they're just for display from a previous owner.
