Air fed mask help please
(In Topic #144640)
I have looked at lots of threads on here and ive not come a cross anything about masks . Also look on other
Sites too . Any help please and thanks to all . :dontknow: :read:
But the thing is i cant do this were my lock up is so is there a way round this . anyone doing it any other way . :dontknow:
scottty said
could put a pipe from the compressor air inlet to outside also you are gonna need a big compressor or two
Got a clarke boxer 150 LTR 17 CFM for painting
and two small power craft 2HP 6CFM
any good :dontknow: And thanks.
Ideally you would use 2 seperate compressors, I think you would be ok using one compressor as long as it was outside the spraying area.
Air fed masks do use a lot of air and can 'rob' the gun a bit, and thats a good reason for an 2nd compressor as well.
You can buy/hire(I think) battery operated ones that go on your waist to save on the 2nd compressor.
http://www.dtc-uk.com/Battery-Airfed-Mask-Kit/p-0-962?Source=Froogle
Bit expensive though, although you could flog it in on fleabay afterwards and get most of your dough back, or buy one off fleabay.
'91 Clipper Cabby
'02 Mk4 Tdi Estate
'67 Riley Elf
'79 Mini Clubman estate
'02 Mk4 Tdi Estate
'67 Riley Elf
not haw yet . thanks for all the help .ill have to give it some thought .
What about an MDF box around the compressor and then use 3 or 4" duct pipe to feed in clear air from outside.
Then, use some more wood or mdf to make a panel that will go under a partly open garage door and cut a hole in it allow the vent pipe to pass through.
(does it make sense??)
'91 Clipper Cabby
'02 Mk4 Tdi Estate
'67 Riley Elf
'02 Mk4 Tdi Estate
'67 Riley Elf
scrag said
just can`t get the compressor out off the fumes . might try and pipe some fresh air to the inlet somehaw
Whereabouts are you planning to spray the car and why is it impossible to site the compressor outside of the area with the fumes?
Mask
In a lock up down a back allay and space out side is nill as cars us it to . Also kids and the local low lifes wounld poss take it or mess with it and mybe harm them self AND I WOULD NOT WANT THAT NOW WOULD I :twisted: . Also like to keep my stuff out of sight you know .
Shiftyseamus said
Been thinking about this……… :dontknow:
Yehh i was thinking on the lines of this to also thought off useing a large fish tank as the box LOL.
anyone done this before and still alive let me know LOL. Thanks for your thoughts and help.
jellybelly said
i it were me
i would just wheel the compressor outside while you're spray
having the compressor in the unit all you will be doing is feeding fumes straight into you face and could end in death!
if you are going to do you it you might as well save the money and have no mask!
Thats it then dont want to die so might put compressor on the roof LOL . im spraying this car one way or anther thanks for takeing the time mate.
'91 Clipper Cabby
'02 Mk4 Tdi Estate
'67 Riley Elf
'02 Mk4 Tdi Estate
'67 Riley Elf
http://www.ebay.co.uk/itm/New-Devilbiss-Finishline-Vizi-60-Full-Face-Air-fed-Mask-/130443600843?pt=UK_Body_Shop_Supplies_Paint&hash=item1e5f0b63cb#ht_1724wt_1020
Anyone got one and are they any good should be as its a Devibliss finishline vizi 60 and then i need a filter at the compressor if ive got it right :dontknow:
