MarsRed Cab 16v Conversion * NOW STARTED*
and i do have a fuel pump if you want it, its a gsf pump thats done about 1000 miles with a vag non return valve fitted, its there if u want it. dont know what u mean by resoviour? accumulater maby?
mk1 golf - resto
mk3 polo breadie - daily banger
It turns out the plug I had connected to the coil was actually speedo sensor.
So I've now got to acquire a mk2 coil to run my forthcoming beast
Rock on
veedubjay said
looking sweet – lovin the engine colour
Cheers pal
Still need to get around to getting the rocker cover coloured.
Was originally keen on a mirror polish but I'm unsure how long the finish will hold up under the bonnet.
Either that or may get it done in a red.
Want to upgrade pads and discs in addition to the larger servo I've fitted and the master cylinder
In peoples opinion would the standard gti discs and uprated pads be good enough stopping power.
Or
Would it have to be a grooved/drilled gti disc and uprated pads
I've currently only got solid discs.
It dunt fit
And some pressed German no. plates.
Does anyone have a pair of radiator clamps or a battery clamp for sale.
Mine were nicely re painted and then thrown away by no one?
As happens all the time.
Get some progress smashed on Saturday.
SHOULD BE PUTTING MY ENGINE IN VERY SOON
PLANNING TO LIFT THE CAR ENOUGH TO LIFT THE ENGINE IN FROM UNDERNEATH
WILL IT GO IN OKAY WITH INLET MANIFOLD AND ALTERNATOR ON IT
OR SHOULD I REMOVE CERTAIN ANCILLARIES
JUST WANT TO PREPARE AS BEST AS TO SPEED IT UP RATHER THAN FIND OUT IN THE PROCESS
I'M PUTTING THE BOX AND ENGINE TOGETHER AS WELL IT DOSNT MAKE IT DIFFICULT
ANY SUGGESTIONS
hope this helped
boyle_sbd said
good work dennis, its comin along now, let me know if u need a hand droping it in or anything as im just up the road from you.
sorry mate didnt realise i hadnt got back to you on this. Is it the fuel pump that sits under the car?
if so does it have the bracket to hold it on as well?
give me a shout
mk1 golf - resto
I put my gearbox and manifold on the engine now.
Just need to put a new cambelt on as i dont know when it was last changed and then it can go in.
Not long now. Ill put an update on here later with a couple of pics.
MANAGED TO BOLT THE GEARBOX, ENGINE AND MANIFOLD TOGETHER TODAY
LOOKS PRETTY GOOD
BLACK DETAILING IS FINISHED ON THE BOX
GOT MY POLO G40 SENDER AS WELL
THE MK2 GOLF SENDER IS INCORRECT FIT
SO ILL BE SWAPPING THE ACTUAL LIFT PUMP FROM THE MK2 SENDER ONTO THIS NEW ONE
HOWEVER I NEED TO ALTER SOME WIRING AS THE NEW SENDER HAS 3 PINS
WHEREAS THE OLD HAS 2 PINS
OLD SENDER AND PLUG
NEW SENDER CONNECTION
NOT SURE BUT WILL IT JUST BE A CASE OF ADDING AN ADDITIONAL LIVE FOR THE IN TANK PUMP
I PRESUME IT IS BUT YOU KNOW WHAT THEY SAY
MOVING ON
I MANAGED TO GET MY HANDS ON A NEW 4 OUTLET MASTER CYLINDER AS WELL
AND…
I HAVE NEW PADS
AND
DRILLED AND GROOVED VENTED DISCS COMING
SO IM CONFIDENT MY NEW POWERPLANT WONT KILL ME..
BEEN STUCK IN AND SO NEARLY FINISHED
CAN'T WAIT
GOT MY NEW MASTER CYLINDER ON
HAD TO SPEND A GOOD WHILE SLOWLY BENDING THE PIPES BUT IT WAS EASIER THAN EXPECTED
REALLY FELT LIKE ONE OF THOSE JOBS WHICH YOU LEAVE TO ANOTHER DAY
HERE IT IS ALL PLUMBER IN
THIS IS THE REAL SHAME
WHAT DO WE SEE HERE?
NO DAMN CAMBELT COVER. THATS WHAT
GOT A NEW CAMBELT SO MY LIFE DOSNT END BUT EURO DIDN'T BRING MY COVER AND SO DIDN'T GET TO PLONK THE ENGINE IN… TUT TUT
ALSO GOT A NEW TENSIONER AS THE OTHER ONE WAS A BIT NOISY
AND IN WITH THEM IS SOME NEW BOLTS FOR THE CRANK COG. OLD ONES WERE UNSERVICEABLE
SO WHILE I WAS BORED UNABLE TO PUT THE ENGINE IN I JAZZED UP MY ROCKER COVER
PAINTED IT BLACK.
RUBBED DOWN THE RIBS
THEN RUBBED THEM DOWN SOME MORE UNTIL THIS
QUITE IMPRESSED
HAS AN ORIGINAL LOOK TO IT AND REMINDS ME OF MY MINI ENGINE
SO BY NEXT WEEK I SHOULD POSTING PICS WITH THE ABF IN THE CAR
STILL HAVNT LAID EYES ON MY BRAKE DISCS
PADS
INDUCTION KIT
AND NOW HAVE A NEW COIL ON IT'S WAY TO ME
ALSO STILL HAVE A FEW MORE JOBS LEFT TO CONQUER
PAINT BRAKE CALIPERS SHINY SHINY RED AS CLOSE TO PORSCHE STYLE FINISH AS POSSIBLE
FIT NEW DISCS AND PADS 15MINS JOB
MOUNTING THE ECU ON THE SCUTTLE PANEL NEXT TO THE COIL IF THERE IS THE SPACE POSSIBLE
FIT FUEL PUMP AND STUFF AND NEW FUEL LINES
WIRE UP FUEL PUMP AND LIFT PUMP
GET MY HEAD ROUND HOW MY NEW ALTERNATOR WILL WIRE UP
TO BE CONTINUED………..
i dont know what order the pins are though as it has no markings, but if you trace the pins from the plug to the level sender uniot and the 2 pins on the plug for the level sender:
1 will be common ground for the lifter pump and sender
1 will be sender only
last is power pin will go to the lifter pump plug only
the lifter pump gets power from the same wire as your main pump
did i include an e/14 pin with your loom?
I know there is the plug I spoke of which leads of from similar near where the lambda one is.
It has about 1.5 metres of length and I presumed that was the fuel pump one?
What does an e/14 pin look like?
the alternative is fit a gti mk1 cab rear loom. you can also put a spade to pin N on the back of the fusebox thats a fuel pump relay output, but you'll want to put a fuse inline with it.
if you look at the engine loom i made for you there should be a spade on it with a red/white and a red wire, thats fuel pump feed for the injectors and lambda. i may have put the E/14 onto that for you, then you just pop to fusebox plug E pin 14 and splice your pump wire to it
Theres a single spade red/black is that for starter?
if its a chunky red/black yeah thats starter. if its got the nice black clippy plug you need a mk3 starter motor. 1.8-2,0 8v if using the 020 gearbox, or a mk3 16v/tdi if using the abf cable shifter box.
you could cut the plug off and put a spade on then use a mk1/2 starter
