Golf mk1 2,0 Gti Berg cup project
I took off the tires because I'm going to refurb the rims, respray them.. maybe sell the to get others, alloy.
Here's some pics of the new parts. Keihin Itb's 45mm
Going to make my own intake manifold in steel, got some parts and going to weld it together and use silicone hoses to connect the itb's to the manifold.
Rides:
Golf mk1 Gti -83
Golf mk1 Gti -83
The engine is coming together and is mounted in the car.
I'm going to make a rear diffuser, looking something like this, it's going to be pretty tall, going from the rear axle to the back of the car and a couple of cm more.
Going to make it in carbon fibre.
Rides:
Golf mk1 Gti -83
Golf mk1 Gti -83
Fat ass
Rides:
Golf mk1 Gti -83
Golf mk1 Gti -83
B
brucieboy said
mmmmmmm wide load!! i really want mud flaps for mine, have these been modfifed at all? or are they specific for the wide arches?
B
Rides:
Golf mk1 Gti -83
Golf mk1 Gti -83
brucieboy said
where did you get them from matey? i think i need them in my life! please share your wisdom!
Rides:
Golf mk1 Gti -83
Golf mk1 Gti -83
brucieboy said
lol cheers mate thanks! i want your mk1!
Rides:
Golf mk1 Gti -83
Golf mk1 Gti -83
1.8T CABBY
1.8T CABBY
richyhill said
very nice, top work ! :-)
Rides:
Golf mk1 Gti -83
Golf mk1 Gti -83
i hope you dont mind me asking but where did you get the berg cup kit iv been looking for a while now with no joy
thanks
gaz
keep on dubbing
83' Driver
As abbouncer says, they are on ebay sometimes. But I got mine from a web based company in czech republic, pesch motorsport. I used google translate and had no problems with dealing with them.
http://www.pesch.cz/vw/vw-golf-i
You can email them in english and pay with paypal. Maybe its them that sells on ebay, don't know really.. might be worth looking at.
gaz_mk1 said
hi great build you have some skills their dude.
thanks
gaz
Rides:
Golf mk1 Gti -83
Golf mk1 Gti -83
Rides:
Golf mk1 Gti -83
Golf mk1 Gti -83
fthaimike said
nice project
Thanks!
Rides:
Golf mk1 Gti -83
Golf mk1 Gti -83
It's hasn't been to much activity lately.. But there has been som changes in the project.
I've decided to run plenum chamber and single throttle body.. as a start anyway.. I want high driveability, even in traffic etc. itb's would look and sound awesome.. but the powerband would be limited to higher revs.. there aren't much space for long runners either.. so probably would the engine feel "empty" below 3500rpm.
So.. I'll run the original intake manifold, an adapter to fit single 2,75" throttle body (instead of modifying the original for tps).
simple scetch of the adapter
bit of alloy for the adapter
Then I've also fitted the g60 fuel rail and weber IW58 injectors. They are good for 394cc/min @ 3bar.. which in theory is enough for 220hp, some margin there.
I got a crazy idea.. hehe.. I've decided to make a diffuser at the rear.. so I cut up the metal.
Made reinforcements at the corners
crappy photo.. but that's where I placed the fuel pump (bosch 044).
The start of a diffuser from glass fibre. Will make 2-3 fins in the middle also.
And finally, got my 14x9" rims blastered and powder coated
Rides:
Golf mk1 Gti -83
Golf mk1 Gti -83
No caps
OEM mk3 caps
A friend is making an adapter to fit 2,75" throttle body to the standard intake, soon to be finished
Got a package this morning, idle valve 2 pins, can be controlled by megasquirt.
I also managed to break loose the rear diffuser, my friend is demonstrating how heavy it is
Did cut down the edges, some sanding and then black paint
Rides:
Golf mk1 Gti -83
Golf mk1 Gti -83
