staggered ats classics question. 8j and 7j
(In Topic #140141)
sproutsy
Tyre size and how low you are will be a factor on whether they will rub or not.
Also the fronts might poke out a bit.
And depending on the backs of the wheels you may need to do some caliper work. I did with my alleycats.
sproutsy
sproutsy
On the cabbys (and I believe later tintops?) the calipers are different and have a kind of strengthening bar on the side. This either needs cutting off or you need to run massive spacers or you need to swap calipers to the ones I believe you have so you should be ok!
But I have never seen classics in the flesh so it might not be a problem anyway. Im just basing this on what I had to do to fit my 13" alleycats.
sproutsy
