Terminal 30 Cicuit?
(In Topic #136652)
Terminal 30 Cicuit?
I want to take some IGN and PERM live from the stock fuseboard, preferrably ones that remain ON when cranking the engine.
Looking at the fusebox info, I can't see any info about the 7 pins for the terminal 30 circuit?
Looking at using it to power a seperate fuseboard for several low load applications such as gauges and digi dash, but also some higher power outputs that require up to 50A.
the other important ones are:
15 - coil live (live with ignition AND live when cranking)
X - x-over live (live with ignition but NOT live when cranking)
50 - starter motor live
31 - earth
Jap is my thing..cant get my head around vag wiring diagrams.
Friggin can't get my head round it!
http://www.clubgti.co.uk/forum/showthread.php?t=219775
I will do some probing when I get the wiring back in
Excellent!
Trying to wire up fog lights, but cannot find where the power source is to come from. For now I've plugged it into a two pin plug near the fuseboard which has 12V at sidelights but not at headlights, and another wire which has 12v at headlights and none at sidelights.
What is that plug for, and where should I really source power from to have the fog light fused at the fuseboard 17..?
Cheers,.
It's not the front, it's the rear I'm doing
Don't have fronts tho!
Oh, and the wiring isn't exactly OE on this truck
but this is how its wired:
fog switch pin 83 - grey/yellow -> fusebox pin M/1 (fog switch power)
fog switch pin 83a - white/yellow -> fusebox pin B/16 (front fogs)
fog switch pin 83b - grey/white -> fuse above fusebox -> fusebox pin B/2 (rear fog power)
fog switch pin 31 - earth
fusebox pin E/10 - rear foglight bulb
sometimes the fog light power comes from a wire stuffed into the fog light socket on the front of the fusebox instead, or from fusebox pin B/20 if it came with front fogs from the factory (again make sure fog relay is in place)
That's what I want to do, use the standard wiring, but I couldn't find which fuse controlled it, or what wire gave the power Like I said about VW wiring diagrams…
K let me check this out…
Switch power, that's power to the illumination, or low current power to switch a relay which uses fog power to go to the bulbs?
This hasn't had it wired in ever!
Thanks!!
