brad mole's mk1 golf project
that was the winter I drove it daily through then :-S
hope youve been cracking on mate
this bit is the main problem i think, im not sure whether to try and repair it and keep the heater blower and scuttle panel, or to just cut it out and weld a panel over to get rid of the blower and tray
brad moles mk1 golf by bradmole, on Flickr
removed the exhaust
put the teardrops on with racing slicks
got some bits for polishing, and some etch primer and bags to keep the nuts and bolts in order
heres the bags so far which ive named up etc.
started chipping off the sound deadning inside, think im gonna invest in a heat gun to make things easier
started removing the wiring loom which was a right mess
engine bay wiring loom and fusebox out
then started on the dash loom and clocks, removed the clocks and dash surround first, then unclipped all the switches and plugged them back in once removed so i didnt get mixed up
dash out, which was easier than i expected
some bits stored in the back for now, started pulling the headlined out, which i really wish i hadnt of started, it was in ok condition to start with but when i tried removing it i tore a bit and thought i might as well pull it all out after that, really not looking forward to replacing it
removed the last of the wires, looking nice and bare now, woohoo
and taped up any holes for now to stop the rain getting in, this is how its looking at the moment
also removed loads of other stuff along the way such as gear stick and linkage, seatbelts etc.
basiclly all ive got left to strip off now are, windows, lights, door seals and
- brake servo
- fuel filler and tank
- steering rack
not sre if it will be worth removing the above 3 things though?
-79 Rabbit 1.5
brad moles mk1 golf progress by bradmole, on Flickr
and 2 new wings
some of the bits ive taken off the mk1, takes up alot of room
and started on stripping down and cleaning the injection system too
thats all for now
removed the brake servo
and removed the fuel filler neck to make things easier, the neck and fuel cap surround actually arent too bad at all which im pleased about
and some pics of the way shes looking now
looks worse than it is here, its just the glue left from removing the sound deadning, main bits of rust are the drivers footwell and insides of door hinges
i think theres just the windows to remove now then she should be ready to get sent off for the dirty work
You decided how you are going to tackle the inner front door pillars?
My Build Thread
mk1 progress by bradmole, on Flickr
also got a bit more of the engine bay and inner arches sanded, just trying to get as much of the work done as i can before it goes to to the bodyshop, ive decided im going to get rid of the heater fan and rain tray, also going to be putting the battery tray in the boot. (excuse the random paint colours, i just figured any paint was better than no paint to protect the bare metal from the weather)
and rested my panels in place ready to get them fitted up to make sure they all line up right when i get time
i like detailed pics… :wink:
also got a new boot hatch
decided to make a start on stripping the engine down over the weekend, after taking the gearbox off earlier, i started on the block, which looked like this
removed most of the bits
and now looks like this
sorry for the crappy pics
also got some new front lights
and some rears, gonna get these tinted all red
also took delivery of some stuff from frosts
and took the windows out, which is the last thing before it gets sent off for welding and paint hopefully
and some more pics of the car, still needs the new boot hatch on and i also need to find some new doors too
all loaded up with replacement panels
bye bye
oh and some new wheels got delivered today too
i sprayed the wheels with the 4 colours i had in mind, and narrowed it down to these two, but i think i will go for the goldish colour
i swapped my crystal headlights for some standard hellas
bought an old radio, which is missing one of the knobs, but i think im gonna try and make my own unless someone has a spare?
swapped the chrome handles for some black ones
and bought a gearknob which i will try and polish in the future (i know reverse is in the wrong place)
and this piece, not sure if its the one i need, but hopefulyl i can use part of it at least
and got on with cleaning some more bits
bought some new paint etc.
with the hammerite paint i painted the none important stuff that wont be seen just to protect it, the eastwood stuff will be for the visible bits
fuel filler before
sanded and high etch primed
satin black painted
same process for starter motor (but used aluminium colour engine paint)
before
and after
and done this bit too
and i need to tackle this next
polished the gearknob up
painted some brackets satin black
bought some centre caps which im gonna try and fit to my wheels (they are too small)
wing bolts and seat clips
before and after painting bits
before
after
still no updates from the bodyshop work yet, athough i have seen the paint sample and all i can say is 8)
been on with the gearbox for aaages now, but heres some pics
this is how it started
and after many hours i ended up with
which i then painted with aluminium colour engine paint and ended up with
i also bought some engine mounts
and started on this mess
split it all down ready to get stuck in
and the outcome
