82 GTI LHASA GREEN TIN TOP, to be something mad!!
should hopefully get my referbished beige leather interior back this week also
pics with number plates..
as some of you may of noticed, i have had the im-bossed zender logo removed from the centre cap, (opinions on this please)
i think it gives the wheel an almost elegant look, especially with the stretchy tyres, 165 45 on the front with 165 50"s on the rear.
i had them diamond cut as i want a real 80's look about the car.
looking good from all angles…really pleased with the overall look now, may even go a tad lower!!
what do you think guys???
Alex
next is starter and new injector sleeve, rear brakes need a look at, and then mot. i have a beige leather interior to go in, which is being referb'ed at the mo, then once mot'd, respray
I like the center caps to 8)
Keep up the good work.
and replaced them with some nice ones without the holes,
and vag bonnet…
a snip at £230 for the pair….
the guys at gpc were very helpful, and found me one of these…
a new injector sleeve, and he gave it to me for free 8)
and the final thing was this…
a new reverse switch, it was from a mk2, but with help from the archives i rewired the plug to make it work..
i now have reverse lights, which was the last electrical thing i needed to get working, so a very productive day!!
Whats next?
redpetemk1 said
Sorted!
Whats next?
starter motor packed up, so i'm waiting for one i bought to turn up, then mot.. then paint
79-85 said
redpetemk1 said
Sorted!
Whats next?
still no go!!!
after replacing the starter motor, still nothing.
checked the new fuel pump and sounded like it was struggling to pump, so removed the sender to find a whole load of black tar like substance in the fuel tank, fortunatly i had a new fuel tank in the garage from my old project than never got off the ground, so this after noon i set about removing the old one, safe to say its a mission.
but after removing the straps, rear beam..
fuel pump and a host of other components, out she came….
followed by the shield….
put the cleaned sender in the new tank, and attached the powder coated shield….
i have decided to overhaul the rear beam while im at this stage and give the underside some tlc
i also jet washed the underside if the tub/wheel well and bought some black waxoil, which will go on tomorrow..while at this stage i gave the inner arches the another go over..
stripped…
One messy job but well worth doing, gunk, jet wash and waxoil to the underside of the tub, hopefully this will keep it safe for a while longer…
before..
and after waxoil…
a vast improvement.
then fitted the new tank and referbed straps, and re-attached cleaned pipes…
while trying to remove the old brake pipes, i snapped pretty much ever end. and as a real kick in the teeth the compensator was seized, one step forward 3 back.
not to worry ordering new ones from crazy q's, along with new anti roll bar straps and poly bushes. on the plus side, i got my referbed rear bench back, now i must admit i'm not too sure, so you opinions would be greatly received…
thats all for now, but hopefully by next weekend i shall have her back together and driving her to the mot station :dontknow:
oh, and we think the gooey black substance in the tank may of been sugar
When do you wanna sort this other rear bench out? I need to get rid of quite quickly :?
MK1 Golf - 1.3l Driver
MK1 Golf - 1.8 GTI (Build Thread - Here)
i was gonna ring you yesterday about it, but never got round to it. could do with it asap mate.wannabemk1owner said
Top work Simon! Starting to come together.
how is going on?
