Kamei Retro Racer mk1 build
Lexan Polycarbonate windows
Decal set:
(you can just about make out the writing on the sheets stood upright) ^ ^ ^
Just a few rear pillar decals to get made & a decision to be made when they are all on in the new year
on how many of the rear ones i go with or to keep it uncluttered with just the main one.
milky said
good detective skills chaps 8)
all i could find was another model pic, taken from this thread….
http://www.automotiveforums.com/vbulletin/showthread.php?t=883251
http://www.clubgti.com…php?p=1856196#post1856196
what is the kit thats on it :wink:
Then after a bit of measuring i realised the hole at the bottom of the winscreen was about 2 inches wider that the legs on the front cage, Hmmm……
So it went in happy through the hole with some tetris style moves, it did not touch the sides :
Little bit of jiggling & it is now upright in the car.
Next job will be to trial fit dash to cut out holes (by heater vents) to go around cage.
Have cut some of the soft stuff away to check the cage starts to fit into the dash though i need to cut the metal piece below the side vents away next.
Dash was then cut/modified to allow the front cage uprights to go through it where the side vents would be.
The cage is now bolted inside to the rear half, the back is now all bolted down to the chassis with extra beefy bolts. I only put 1 for now into each main hoop legs to allow them to pull the feet down to the floor while i start the bolting the front feet down.
The main hoop bolts will be a pain to do as they nearly all have to be cut down to size due to the lip by the sill on the inside making it tight.
this is an early pic:
showing the floor plate, image 4 bolt holes drilled into it and trying getting to the rear bolts with a nut/washer especially over the sill lip).
& you have the seat bars also to climb around while holding a spanner (with a nut/washer taped to it) to slide along inside & trying to screw the bolt down into it while puting a pulling bar in a spare bolt hole to pull it all into line lol.
Finally got everything bolted down on the cage & only had to cut down four bolts.
With the main hoop i had to make a wooden tool that held the nut in place while shoved into the box section at the back holding it until the bolt gripped then i would wedge a large screw driver against the nut to stop it turning while tightening, worked a treat.
Passenger side by where the windscreen fits looks fine though the driver side looks a fraction more out so if it touches the screen i might try a strap on it to pull it in a tiny bit (i was thinking if it didn't move i could remove the cage bolts on one half of the roof bar sleeve on that side for it to give a bit then re do them in situ?).
Fitted the rear side lexan polycarb windows in:
I've been following this closely, top quality work :clap: hope to catch it at a show when it's finished
Driver side:
Passenger side:
I won't be drilling the tunnel until i trial fit the seats again which are having new runner plates made.
Cage front passenger side (looks ok):
Cage front drivers side (looks a bit further out so not so good):
I am hoping the bar will pull in a bit after i get a ratchet/strap on it cage is sitting with a very slight twist in it.
If it doesn't shift after the strap/ratchet on it i will try removing the nuts from the sleeve then if that doesn't help it move i can trim a fraction off the end of the front half where it goes into the sleeve so it has a bit more room to move though hoping not to have to do that as we are only talking of about a cm.
(clicky, old pic to show sleeve)
Picking up a ratchet from a friend this week to see how it goes.
Been doing some sorting out & found these expensive paper weights :redfaced:, hope i get to use them some time:
Also found this chunky badge though not sure when or where i bought it from?
