Golf Gti Campaign Breaking
Many parts still left
Do you still have parts left , need clicks from centre console , leather gaiter ,red bonnet, glass in green tint , rear parcel shelf.
hi, do you have a tin top centre console available. Thanks
Hi, any genuine hella rear light clusters?
Have you got any rear tin top seat belts?
Hi Mate
You got any of the below : -
1. Rear Bench ( Tin Top )
2. Rear Wiper Motor
3. Door Mirrors
4. P Slot Centre Caps
Do you have black carpet, if so I need the separate piece that goes under the bonnet pull in the passenger footwell..?
Hi mate. , I'm looking for the lower bolt that connects the alternator to the engine block?
Hi after tin top gti drive shafts only pm me thanks
I am after the front Seat Runners / Base, and complete locking set ( Doors, Ignition, Tailgate and glove box ), door mirrors ???
thanks
Do you have the oem orig black carpet front and rear?  Mo mk1gti79
Do you have the rear boot seal? Also looking from front door window seals the deal on the outside at the base of the window.
Have you got a genuine tailgate lock? I don't need the key.
Desperately need the small clip that holds the bonnet cable to the slam panel.
Hi, does the shell have a sunroof? If so how much for the roof with the sunroof components attached. Also do you have doors(3 door)?
Yes I've got all that. Send me a PM with your mobile
No. and ill phone you tomorrow
Do you have the steering wheel nut?
Do you have a single light grill?
Looking for the small breather hose that comes off the cylinder head between no3 and 4 injectors VW part no. 067 133 642B
CHEERS
Restoring the suspension on my 83 GTi Campaign back to standard suspension - The parts suppliers only sell the "one spring fits all" option.  The GTi had different springs which were 20mm lower.I am looking for a set of good GENUINE STANDARD GTi SPRINGS .
I must stress that I need genuine GTi springs, not lowering springs and not springs for 1.1/1.3 etc…. Thanks.Guy WILSON
hi have a early outer cv joint ,not after one where the circlips fits at the end of drive shaft thanks.
