Buddy MK1
1983 Pirelli Edition
Hi guys and girls.
I started a couple of threads on other forums so thought I would copy my progress so far over to here.
I use to own a mk4 golf gti which I built up to this stage:
The mk4 was a great daily and served me well for a good few years but I felt I had taken it as far as I wanted to so stripped it for parts and purchased a new daily and a new project.
The new project is a 1983 mk1. It came with a 16V lump in it, mk2 leathers and some banded steels. I made the trip down from Kent to Bridgewater to pick it up and the drive home was brilliant. Drove well and sounded great.
Initial plans were to simply tidy it up, find a nice set of wheels and deck it. It had already had some work done to it including a full respray, new wings, sills, and front end. I was offered some turbo its in p/x for the banded steels so before I knew it I had an engine build on the c ards aswell.
I then set about removing the 16V inlet manifold and the 4 branch exhaust manifold to make way for the turbo bits. These includ ed T3 Turbo,  Turbo manifold,  16V/ 20V inlet manifold with AGU TB,  20V fuel rail and injectors, and a front mount.
10205840175_6422f8cdec_c.jpg 10205842076_8b999a8ae1_c.jpg 10205842236_144f9b39f1_c.jpg   I then got a little distracted away from the engine and started gutting the interior. This included seats out, carpet out and remove all the original sound deadening (which took TIME)  10206221083_b422f1d58d_c.jpg 10206116655_69d2170d07_c.jpg 10205948933_e9b3f44e9b_c.jpg 10206124233_e1ab1033f9_c.jpg  Once the bulk of it was out I cleaned it up with some thinner, repaired a few areas which were rusty and applied some zinc primer. The passenger footwell has rusted badly where it met the sill so I bought a replacement panel and ditched the rusty one. The replacement panel is pretty thin in comparison to the original material so I tried to keep as much original metal as possible.  10205669304_09a3a98bbf_c.jpg 10205875493_c03d382c48_c.jpg 10205763765_1a445c33c8_c.jpg  While working on the inside I also put in some sound proofing. I work for an AV installation company and we use Silent Coat in some of our speaker boxes which works really well so I decided to use it in the mk1 aswell. The doors, rear arches, roof have been done so far and I will be doing the footwells and the boot floor later on. This stuff really is impressive. I cant wait so see how much it reduces the road noise.  10205939133_e544e50abf_c.jpg 10205726484_2198d21147_c.jpg 10205819076_765db7f2d8_c.jpg
Next were seats. I was originally planning to swap the mk2 leathers that came in the car for some mk1 GTI seats but I had the old Porsche 997 seats sitting around so made up some brackets to house those. I used some old mk1 frames as a base.
 The plastic backs were pretty beaten up so I pulled them apart and retrimmed them in a suede/ alcantara material. I think the result will help to make them look more at home and not too put of place. It certainly helps to date them slightly.
10205662734_2294805428_c.jpg 10205618154_30eb0d8976_c.jpg 10205705435_652253f3ec_c.jpg 10205808033_2008ffc15c_c.jpg 10205799593_a2b22225ef_c.jpg
 I initially didnt cover the airbags but after refitting them it was obviously that they would need to be covered aswell
10205699005_7707dfaaf7_c.jpg 10205593214_ecb6fdddce_c.jpg 10205692495_7509605649_c.jpg
The base panels will also be trimmed once I find some spare time.
So just as I was ready to start working on the engine again I stumbled across a 1.8T 20V with full loom, ecu, gearbox, driveshafts, turbo, all ancillaries (basically everything I needed) for a cracking price. £180 to be precise. So out came the 16V.
As the bay was empty it would have been rude to just put the 1.8T in there and not tidy it up a little so out came the battery tray, off came the brake servo, MC and balance bar, off came all the seem sealer, and all the unwanted holes are being welded up. Im new to a lot of this kind of work so its taken me quite a bit longer that it would most.
10205657884_ef5baa15d7_c.jpg 10205761805_4f499c5a73_c.jpg 10205655784_5f4786ee5b_c.jpg 10205754925_a68433ca80_c.jpg 10205751695_400f351ddc_c.jpg 10205646054_b31d7cf965_c.jpg
In between working on the bay and interior, I started to tidy up the new engine. All unwanted items were stripped off, 16V tensioner, new waterpump, cambelt, custom engine mount, and a lick of paint.  10205881203_b2bfcdd48e_c.jpg 10205784026_f69594676b_c.jpg 10205892503_19e95d1658_c.jpg
1.8 non turbo cam cover
Onto wheels. I originally wanted to try and find something a little different to the norm. I found a few potential options but stumbled across a set of BBS RS047s for a decent price so went for those.
Before buying the RSs I tried a couple of other wheels that were to hand just for a bit of fun.
Cookie cutters
Porsche twists
Teledials
My old ETA Betas lol (a little big)
Pirelli P Slots (a strong contender)
H's RSs
The came in a lovely shade or orange and had 2.5" dishes up front (9J) and 3" on the back (9.5J). After a quick test fit on another mk1 it was clear that these specs werent going to work.
So I took the tyres off and discovered just a little bit of silicon.
I sent the barrels off to be powdercoated, ordered 1.5" and 2.5" Radinox stainless dishes, ordered new bolts and had the stripped the centers.
The dishes and bolts came from FelgenFuchs in German. Great service and very quick delivery.
Stripping the centers
As I had already painted some of the engine parts in crackle black, I thought I would continue this onto the wheels.
Putting them back together
I also have quire a good stockpile of parts ready to go in/on.
AP coilovers
Front mount
Polo top fill rad
Full loom made up by Vagtronics
New carpets
New headliner
Downpipe flange etc
Cracking project thread mate. Sounds like you got an absolute bargain with the engine.
Good luck getting her finished off.
Smudger
Wow welcome to the club :) great write up looking forward to your updates !
Out of interest was the car for sale on SW Dubs forum? I think I recognise it??
Scott
South West Regional Host
Previous;
Current;
Great start to your thread. The seats look amazing. Keep the updates coming   :thumbs:
Matt
Cheers guys. I have a full weekend working on the mk1 so hopefully I should be able to get the underside fully stripped and resealed.
Scott - not that I know of but it may well have been. I found it through eBay
I hate projects like this, thwy make mine look rubbish :) kwwp up thw good work buddy, them wheels look amazing :)
Click on the link below to see my mk1 16v project
http://vwgolfmk1.org.u…-16v-project#post_1081899
this looks amazing welll done
i want to do the same with the crackle paint on my block- what did you use to do it ? and also it looks like you pianted it with normal paint first then did the crackle ?
Looks good mate, will be following this for sure! :thumbs:
2018 Up! GTi 1.0 TSI
2015 Mk7 Golf R 2.0 TSI 4motion DSG
2011 Caddy Maxi Kombi 1.6 TDi
1982 Mk1 Golf GTi 3 Door 1.8t - Build Thread
really nice build thread this
like the crackle black stuff
Stunning build so far, loving the quality of your work!
Can't wait to see this finished :)
1973 BMW 3.0CS "Helga"
1981 VW Golf GTi "Agolf"
1986 Ford Escort RS Turbo S2
1987 BMW M535i - 'Klaus'
Instagram: @ahmet_e9
cheers guys.
gelstharp - I used VHT wrinkle paint (http://www.ebay.co.uk/itm/VHT-BLACK-WRINKLE-FINISH-SPRAY-PAINT-SP201-/350812972072?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item51ae152428) When you spray it on it looks like a gloss finish then over 24 hours is wrinkles. It needs to dry in a warm environment.
Had a good weekend on the car. Finished stripping the underside back to bare metal. one of my rear beam studs snapped when removing it so I cut it down, drilled it out and dropped a new bolt in from the top.
There is a handy little slot inside the car which is nearly directly above the studs. I dropped the bolt in and welded around the head to keep it in place. once secured I trimmed it down to match the others.
 Last night I managed to get the last of the underseal sprayed. I always manage to get more on me and in my hair than I got on the car lol.
I also managed to start getting the front control arms, hubs and suspension back on. I had the control arms, rear beam, ARBs and a few other bits powdercoated. Iv also fitted super pro bushes.
Its nice to see parts finally going back on. Hoping to have him back on the ground within the next week or two.
So I took one of the RSs for a drive down to test fit onto the mk1 after work yesterday.
Bolted it on to see how the 1.5" dishes sat and was happy with how they looked. A little bit of poke but no where near as much as before. The should tuck in a little more then the car is actually on the ground and at a sensible height.
It was only when I tried to raise the wheel up closer to the arch that I realized that the coilover collar is going to foul on the barrel. I currently have the camber adjusted to maximum so it may be that they will clear when reduced. I dont really want to space them as they poke enough already.
A few suggested options would be to raise the strut towers, narrower barrels, smaller dishes and then space the wheels, remove the helper springs. Plenty of options so im sure I can sort it out.
Small update. I got the gearbox cleaned up and painted.
Amazing how after a clean and a lick of paint, these gearboxes look great again.
Nice job  :thumbs:
Matt
Thanks Matt
I managed to get the rear arb on the rear beam last night. The arb brackets are such a pig to fit but I got there in the end. They went on a little wonky but a bench vice straightened things out.
The rear beam is now back on the car and Im hoping to put the stub axel and disc assembly back together tonight. Can offer up the rears then. Cant get enough of these
Well that is just mind blowing, what a talent you have, I take my hat off to you!
I am blown away by your skills!  :thumbs:
Oh I nearly forgot, a very warm welcome to the Club.  :)
what a mental thread I LOVE IT !!!
