not running right
(In Topic #192892)
any help would be nice
thanks tom
Check all your earths and look for damaged wires, check you have not had water get to the fusebox
lhasa green 83 gti tintop MOT passed Aug '14 after nearly 12 years!
Audi A6 3.0 tdi Avant Quattro Le Mans 305bhp
Check fuel tank and filler neck for rust.
When was your fuel filter last changed?
Checked for air leaks?
Checked your accumulator is not leaking from the screw on the rear?
These are all things I've sorted on mine and ended up not being one specific thing but lots of small tweaks
Magic-GTI said
I'd be tempted to have a look at the injector seals they get hard over time and only start to soften with heat, I.e. When the engine is warm. Sounds like your running symptoms.
yeah thanks mate, its currently in my dads mates garage getting looked out and he has said that the bother outer cylinders are getting drowned in fuel and also discovered an oil pressure problem now its too high
