New linkages and bushes still problems
(In Topic #196300)
have you ensured the gap is set at 19mm for the white lever ?
By step, before the linkage changes it had the same problem even tho some of the bushes were in a bad way and also one link way shot, I'm just wondering would it be a gear box problem, but when it did this before you had to really push it towards 4 to get it to slot in to 4th the car had been stood for a very long time 9 years I believe and has only had a trip here am there for moting, I think she might need a Italian tuning lol but still would be nice to know what else I can look at to sort this out I will hopefully do the oil change so that's sorted
Gear Change Linkage - The Mk1 Golf Owners Club
if the stick goes over to reverse without pushing down sounds like the stick housing that bolts to the top of the tunnel is to blame
edit: what engine is it?
or if its a 4 speed, maybe it has some 5 speed parts lol
piccy up your linkage and hopefully someone can spot if there are 4 speed parts in there or not.
try manually selecting gears at the box lever, take care when shifting though dont put too much force in you can overshift and lock it as i found out showing a box to a potential buyer lol
VW oil is good stuff, shouldnt be too expensive either
