Master cylinder changed and still the brakes are w**k!!!
(In Topic #198224)
I used my pressure bleeding kit again and checked there was no air but i realised that the 2 brakes which are fed from the front end of the master cylinder, i think its the secondary chamber, were literally dripping fluid out slow as hell when there should be a good solid stream (pressure kit was set to 12-15psi). The other 2 brakes bled great.
Is the new master cylinder nakered?? seals leaking?? or return spring stuck??
If i pump the brakes, sometimes it might have some resistance but then it will go again
If you are still getting problems is the any restrictors on the brake line?
Have adjusted the brake compensator?
lhasa green 83 gti tintop MOT passed Aug '14 after nearly 12 years!
Audi A6 3.0 tdi Avant Quattro Le Mans 305bhp
Well at least i know then that ive not wasted my money on 2 new cylinders because it cant the the compensator as i dont have one. Its a start i guess.
Can anyone confirm though that when you fit a new cylinder, along with bleeding the system, there isnt anything else i need to set up. its a simple bolt on the the vacuum with the o-ring and then away you go etc.
Martin.
Might sound daft but you dont need to prime the cylinder first do you with the new fluid before you fit the fluid resiviour etc?
