Gearbox oil change question
(In Topic #197157)
One guide mentioned rather than do the final top up through the sppedo, to keep the car jacked up on the passenger side so the gearbox is then at an angle and you can then get the full 2 litres through the normal refill plug (providing i have checked it comes undone first!).
Has anyone done this, and if so how high do you need to jack the car up?
The amount the car leans with the wheel up won't make much odds to the level. It just maybe slightly over filled if you put the plug in with the wheel off but I'd rather see a little too much then not enough.
