Gear linkage shift rod question. Please help!
(In Topic #188047)
Could I lose gears again
Not much £ for piece of mind!!
1987 Caddy 1.6Turbo Diesel-GTD
Instagram: Cavscp
Instagram: Cavscp
cavs said
If it's worn then probably best to replace it as they are only cheap.
Thanks mate. Do you have a link to the part required as not entirely sure what it is. The mechanic said it was the one that lined to the 'pinch bolt' How easy is it to replace? How can I keep the linkage all nicely set up? Can I mark it before I remove it so everything goes back the way it was? The gears are going in really nicely .
Had to get back under and tweak the rod you mention by about 2 splines, not a lot when you measure it, maybe 2mm, been fine since with 250 miles under its belt.
