BC coilovers - any good?
(In Topic #199653)
1992 MK1 Golf GTi Rivage - Classic Blue Metallic - Long term project
1991 MK1 Golf GTi Rivage - Classic Green Pearl - Sold
Peterg60 on here has them and I'll be fitting some over winter 👍
Have you found them any cheaper than here?
mk1 daz said
http://www.classic-vw.co.uk/mk1-golf-bc-racing-coilovers-6003-p.asp
Nope, cheapest i've found! Although they are based in Bradford so might go pop them a visit and see if they can look after me.
peterg60 - What you think of the coilovers? Any good?
Group buy 👍
You can select which springs you want for which engine you have.
mk1 daz said
Isn't Classic vw down south somewhere?
Group buy 👍
That was my next question.. Spring rates. How do you know what's what?
Mines a Rivage Cabby and i'll be 20vt-ing or G60-ing it!
8kg front and 7kg rears
We both have 20vt's.
I don't know what drop they offer though?
mk1 daz said
In going for the same setup as pete.
Tintop's or cabrio's? Road or track?
What's the reasoning for those weights - I believe that is the stiffest they do
Pete does trackdays and drag strips.
I plan to do both too but mainly street.
Not sure why I just take what he says as right, helped me loads with my "money pit"
mk1 daz said
Both tintops.
Hmmm, mine will be mainly fast road. It's a weekend toy so performance over comfort but I don't want a stupid un-drivable ride, especially around here on pothole central.
I contacted BC and explained the same where they said the default spring rate (aimed at fast road / occasional track use) is 5/3kg/mm so either that or 6/4kg/mm should be perfect.
I know the late Cabby is around 150kg heavier but I wonder what he distribution difference is?
I know pete uses his on the road as I will be but I too don't want the dashboard trying to rattle off its mounts.
I'll be maybe letting you know then 😉
