Help needed on the GTI Kjet tronic system
(In Topic #192931)
I'm looking for some info on the GTI fuel injection system. I've searched the forum but struggling for what I need. Could do with some sort of schematic diagram just so I know what's what etc.
I've checked everything on my MK1 to run it (recently purchased) as its been stood for 4-5 years. Its all good to fire up but want to flush the fuel system of the old juice.
Is there a drain for the fuel tank before I scrabble under to find out there isn't and what's the best way to flush the pipework up to the engine?
Any advice would be appreciated.
Ta muchly!
Regards Volkswarren
RichardHall said
I took off the pipe tat goes from the tank to the fuel pump, jacked the car at an angle and drained off as much as I could - it has 14 yr old four star in it! Put 10 litres of super unleaded in, changed the fuel filter and cleaned out the injection meterring head with carburettor cleaner and all was fine.
wow. im struggling at the moment to get my "caster" clipper through the MOT due to emissions..he's got a catalyst and after 2yrs stood he's been stubborn to improve is hc and co2 emmisions, thats after doing italian tune up, and running on 1/2 tank of fresh fuel.. Not sure what to try next, if old school tuners cant get him sorted.. may have to look at set of injectors.
On the drive
Myvalver 89 GTi Grey mk2 16v
Failing that. .. find a better MOT tester
mark1gls said
That must be a late car to have a cat fitted, have you tried adjusting the mixture when its running on the CO2 meter?
Have changed all filters for new..but not tried it without one.. The car is a clipper on k June 93.. tax expired July 13.hadnt been run for 18 months minimum. Was hoping my third and second gear blast across lincoln would help. Suppose find out tomorrow if a mot Tuesday. .maybe another mot will find another set of issues. Already spent 50 hrs and ££££ on getting the first mot failures sorted.
On the drive
What are the emissions readings? High HC normally suggests a misfire.
On the drive
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=fuel-systems-and_4%2Fk-jetronic-troubleshoot_2
k-jetronic adjusting warm-up valve, system & control pressure on golf mk2 gti - YouTube
http://www.honestjohn.co.uk/forum/post/index.htm?t=40638
a little bit more info for andy.
On the drive
Lets get Christmas and new year out of the way and then its time to make pretty and to repair the oil leaks that have come due to neglect.
On the drive
http://www.edition38.com/forums/index.php?showtopic=399683
On the drive
