wire help please :)
(In Topic #192260)
So i tried to decipher which wires were which and where they go in the engine bay and there's a couple behind the fusebox.
I have looked through the haynes manual, and found out a few of the wires, but theres still some that i dont know what they go to.
any help will be appreciated;
In the engine bay;
1.
2.
3.
4.
5.
6.
Behind the fusebox;
1.
2.
3.
4.
5.
6.
thank you!
a/b - 2 valves behind the carb
c - carb heater
2. handbrake switch wire plugs to this
3. grey thermoswitch in flange on front of head (for 2e2 carb)
4. carb heater i think
5. dimdip resistor, ignore
the yellow/white and brown 21 pin plug in last pic is front fogs, that shouldnt have anythign plugged into it either
it looks like you have an 02j gearbox in there? if so i guess its a 20v swap? if so ignore plugs 3 and 4 also
