Wire and plug help
(In Topic #191467)
I am a bit confused as what type of wires I need to sort the problem so here goes with the questions.
Looks like the short occurred between the steering column and the lights switch on the dash.
My questions are…..
1) Where would be best to get the wires from and which type. I want to try to get matching wiring to keep it as simples as possible. Looking on this website http://www.vehicle-wiring-products.eu/section.php/48/1/cables/98059a32239199a30add879df7cc2e9d there's 3 types to buy. What you guys recommend.
2)I want to source the flat plug in the last picture to replace as it's a bit scorched. Can these be bought new from anywhere?
3) Is it worth replacing the light switch while I am doing this job and if so where can I get one?
Any help would be greatly appreciated.
Smudger
Cut back as far up the loom as I could, soldered and heat shrink, access is awkward but not impossible
lhasa green 83 gti tintop MOT passed Aug '14 after nearly 12 years!
Audi A6 3.0 tdi Avant Quattro Le Mans 305bhp
I prepped the ends of all wiring before hand so just cut, slide up a bit of shrink tube,twist the ends together and solder
These are the work of the devil!!
http://www.ebay.co.uk/itm/100-Blue-Scotch-Lock-Wire-Connectors-Quick-Splice-Terminals-Crimp-Electrical-12V-/231083342911?pt=UK_In_Car_Technology&hash=item35cda3fc3f
mark1gls said
If you find any more of those blue scotch locks in your wiring remove them as it's not the best way to connect wires.
Agreed Mark. Looks to be only that one in my loom so it will be getting removed.
Have posted in the wanted section for an interior loom as it would seem easier to cut and splice in as suggested by ppc229w.
Will see if anyone has one they are willing to cut up for me or buy a whole interior loom dependent on price.
looks like the parking light system shorted out somewhere, plus as said trace the bodgery from that scotchlock
Don't worry the bodgery will be going. Have managed to source someone with a loom by the looks of it who is willing to cut the bits out I need to will be splicing in the new bits to hopefully sort the problem
Smudger
g60gerry said
Hi, just by looking at your pic , are you sure it was caused via a cross wire?? why did not a fuse blow..To me it looks like you have an over load of current issue…
No fuses blow at all mate. Looking at it it's just the one plug issue between the steering column and the light switch. I have removed all the plugs a few times in my ownerhsip of the car to remove the column and fit a new one and then to make some adjusments.
I have relocated the battery from the bay to the boot recently. Would this have caused it??
Smudger
Last edit: by rubjonny
rubjonny said
there isnt a fuse for every live feed on a mk1, relatively few in fact. the light switch power feeds and parking lights are just 2 that aint fused
So could moving the battery to the boot have caused this then in some way rubjonny ?
1983 Golf GT 2.1 16V with throttles/1978 Golf LS 2.1 ABF with throttles/2008 Citi Storm 1.4i/2007 Hyundai Getz - my daily
As this fails it caused the main corresponding wires to bear the load. Evidently leaving the wires in same state that yours.
Is this the only plug that's damage?, have you checked all plugs and connectors behind the dash?
