Water temp warning light
(In Topic #185224)
Mine is flashing constantly but needle works perfectly, temp sensor is new.
First link I found to what the sensor looks like.
http://www.ebay.co.uk/itm/Expansion-Tank-Water-Coolant-Level-Sensor-VW-Golf-Mk1-M2-Polo-T25-K-Jetronic-NEW-/360851759900?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AGolf&hash=item540470e31c
You can see it on this expansion tank.
http://www.ebay.co.uk/itm/VW-MK1-GOLF-CABRIO-GTI-RADIATOR-EXPANSION-HEADER-TANK-COOLANT-LEVEL-SENSOR-CAP-/310936719367?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item486545d007
try bridging pins on level sensor plug if flashing stops coolant is low, switch faulty or tips dirty. if not wiring, relay, temp sensor or dash fault. pull the 42/43 level warnign control relay out of its socket. if flashing stops its the relay or level sensor wires, if not its coolant temp sensor, clocks or wire fault
When the rain stops I'll have a go! Lol
I have disconnected the temp sensor and level sensor, light still flashes.
I will try bridge the level sensor and try that.
Light still flashes!
Can incorrect water flow effect this light as the water hose I replace has a bit of a kink in it. New one on order.
Just the light that's has an issue, bugging the hell out of me.
You say 42/43 relay, is that the name of it as by the look of the fuse/relay diagram, relays only go up to 24?
it should be clipped to the top of the fusebox, look for the holder with red/yellow or blue/yellow, plus red/blue black/yellow and brown wires to it.
bridging the pins on the level sensor plug will rule out any issues with flow/level/whatever and point back to the relay, wiring, temp sensor or clocks
Got one with 43 on it, no 42
rubjonny said
as in the one with 42 or 43 on the front
Note the words "42 OR 43" (meaning you will have one or the other)
Well pulled out relay 43 and light is still flashing, I am very puzzled now, surely it shouldn't work at all after that??
Would one say this relay is not doing anything, although even when pulled out my light still flashes lol
the coolant temp wire goes to bot the relay and the fusebox so it can be damaged if the relay suffers water ingress. what happens is the level sensor pin seals fail and coolant wikes its way up the level sensor wires into the relay and rots em out, I see it all the time on the looms I make
I will do my best now to get to the bottom of the problem.
Keep you up to date
Could there be a fault with the temp sensor itself, although it's only 2 months old.
Well I think I will check the fuse box first as my oil light and buzzer is playing up too
Does anyone have a diagram of the back of the fuse box??
Asking a lot here I think
Does not seem to do her Golf any harm, it only upset Sheldon.
I had another problem with all the clocks going dead when I switched the lights on, the earth on the rocker cover seemed fine, in desperation as MOT was due and I needed the main beam warning light to work, I started to take the instrument binnacle out, but could not release the speedo cable, pushed everything back and by fluke everything worked when the lights were switched on, and the temp flashing cured itself. So might be worth checking the wiring plug on the back of the instruments in case it's loose.
