Twin fan setup
(In Topic #191524)
for my 1.8t conversion I have got a skoda felicia 1.9d radiator to locate the outlets to the near side. With this I have purchased a couple of slim fans, both 80w and i am looking for advice on wiring them in.
Current mk 1 wiring is as follows:
Red wire from 30 amp fuse in fusebox goes to temp switch (2 pin)
red/black from temp switch to rad fan
brown from fan to earth.
For the time being I wish to keep the 2 pin switch (single speed) and have both fans on full speed when the switch activates. Can this be done like a daisy chain or will this overload the current fuse/relay, esp on startup? Would I be better running 2 stand alone relays near the battery ? If so any recommendations for waterproof units ?
pippo
Last edit: by Torker
1983 Golf GT 2.1 16V with throttles/1978 Golf LS 2.1 ABF with throttles/2008 Citi Storm 1.4i/2007 Hyundai Getz - my daily
I will try wiring them in direct and see how I get on.
I was planning on using resistors to bring both on at half speed for low temp switch and full throttle for high temp.
Pippo
Pippo said
Cheers torker,
Pippo
That will work, my BMW used a resistor to bring in the fan on low speed when the aircon was switched on and full speed when the coolant got hot. If you can find one of those resistors (off a E28 BMW) it will simplify your wiring somewhat.
but the correct way is to first check the amp rating for the aftermarket fan(s), and make the load doesn't exceed the fan fuse which is 30a. if it does fit a relay, if not dont bother
fitting a relay regardless isnt a bad idea though, especially if the fusebox or wire is past its best.
alternatively if your fusebox/wire is bad just run the live for the fan direct to the battery with suitable gauge wire and inline fuse to suit the rad fan requirements. Aftermarket ones tend to be lower ampage so you can reduce the wire/fuse accordingly
