Polo 6n2 Dash into Mk1
(In Topic #191721)
Help Please
I picked up a 6n2 Polo dash with cluster and wiring for cheap and want to put it in my golf Mk1. Anybody maybe have a wiring diagram for the cluster please as i would like to pair it into my Mk1 harness. Any help will be appreciated.
if you have the later blade fusebox look at jetta89.pdf, that covers the pinouts for the fusebox. for the mk1 cluster:
T14 - CE1
1 - blu/gry - Light switch pin 58b (dash lighting)
2 - brn - Earth
3 - pur/blk - Fusebox pin B/3 (fuel level sender)
4 - blu/yel - Fusebox pin B/7 (coolant temp sensor)
5 - red/blk - Fusebox pin B/19 (rev counter)
6 - red - Fusebox pin B/12 (permanent live)
7 - blu/wht - Fusebox pin A/28 (high beam warning)
8 - brn/wht - MFA switch mode button
9 - blu/blk - Fusebox pin A/4 (high oil pressure warning switch) (blk/blu on early models)
10- brn/red
11- yel - Spade to engine loom behind fusebox on early, Fusebox pin B/15 late (low oil pressure warning warning switch)
12- blu - Fusebox pin A/16 (alternator warning light)
13- blu/red - Fusebox pin A/17 (indicator warning lamp)
14- blk - Ignition switch pin 15 (ignition live feed)
T6
1 - wht/blu - outside air temp sensor
2 - wht/red - outside air temp sensor
3 - grn/blk - Fusebox pin B/15 on early models, spade to engine loom behind fusebox on late models (oil temp sensor)
4 - blk/yel - Fusebox pin A/3 (Gearshift control relay pin 3/L)
5 - wht/grn - Fusebox pin B/18 (Gearshift control relay pin 5/G)
6 - wht/yel - speedo signal
if you plan to keep the mk1 fusebox then you'll have to add a fly lead from dash loom to the engine loom to get the sensor output, if you go for the polo loom then you can leave it oe you just need a polo engine loom to match the dash so you have the right connectors. same goes for the rear and lighting looms
I just want to make sure, are you swapping in a Polo dash or a Velo dash? If it's a Velo dash make sure you get the complete harness and all the control (boardnetz) units with. In the latter case I can assist you with a connection diagram to connect the Dicktator to the MP9 harness.
Last edit: by Torker
1983 Golf GT 2.1 16V with throttles/1978 Golf LS 2.1 ABF with throttles/2008 Citi Storm 1.4i/2007 Hyundai Getz - my daily
Its the Polo Millenium dash i have the harness for the dash and i will be running a 20v hybrid with Dicktator. I have all the plugs for the dash aswell as the fuse box it came with
