oil light flickering on idle
(In Topic #193579)
It's all shits and giggles until someone giggles and shits
I'm no expert but I'd be looking closely at that before anything else!
golfcabrio said
As you have a none standard setup up, I'd look at the wiring first.
Will do
What reading are the gauges giving?
sallyandsean said
Just had a look and the spade connector didn't look too cleaver and came off the wire in my hand so changed it and seems all good. Thanks chaps
All's well that ends well.
as above whats the oil pressure gauge say when light is flickering?
rubjonny said
where is the 0.3 bar switch? are you using a 2 pole oil pressure sender, or is the 0.3bar switch seperate?
I have no idea what you even said there
gauge readings look fine while at about 15 to 20 ish, it's only when iv been driving for more that about 30 mins.the switch is blue with one spade connecter if that helps?
Last edit: by sallyandsean
now for the oil pressure sender, some have 2 poles on them 1 for the gauge, 1 for the oil pressure switch warning. the 2 pole ones replace one of the old pressure switchers, and the most common ones replace the 0.3 bar switch. this is i ask if you have a 0.3 bar switch, or if you have a dual pole switch for the gauge.
also, oil pressure is higher at the oil filter housing than it is at the cylinder head which is why i ask where the 0.3 bar one is
what does the oil pressure gauge say when the light is actually flickering?
maybe the pressure relief valve in the oil pump is stuffed
10psi is 0.7ish bar so it shouldn't trigger the light. maybe swap the 2 wires on the oil switches over? they're opposite colours from abf to mk1 so it could just be that
rubjonny said
ah
Ha ha. Will give that a go pal.
