Non start issues
(In Topic #192156)
I might be being stupid but I'm sure someone will set me straight .....
I have a 1988 golf clipper cabrio auto and I have a starting issue.
It happens only when the engine is warm/hot I try and fire up the engine say after filling up and it won't turn over. The previous owner has tried a new starter motor and that has made no difference, so he has proceeded to fit a hot wire button.
Basically this is wired straight from the battery to the starter motor via a button and the car doesn't fail to start.
So does anyone have any ideas where to start as I want the engine bay back to standard without extra wires and I fear for the security of the car with the hot start button.
Thanks in advance
Adam
Old dubs never die, they just get lower
I only ask as even repeated attempts to start or wiggling the key has no effect ??
Cheers for your help with this as I can't find much that seems relative
lets see if this works !!!!!
Fingers crossed everyone.
Just to clarify then it would be a relay in the ignition live to the starter motor with a permanent live from the battery ????
You dont have any info on this do you ???
Cheers ad
30 - battery +
86 - old red/black starter wire
87 - to starter
31/85 - battery -
you could put an inline fuse on the live feed if you like, but the factory trigger wire isnt fused
well its in at the garage now having the switch fitted either way - at least its a piece of mind.
If that doesn't work then happy days I be giving myself another electrical shock on Saturday.
Thanks everyone for your help on this, its genuinely appreciated.
if you wanted to keep it VW look for a #53 relay thats the same as a std automotive switched relay
I'm scared of setting my motor on fire by being a complete moron !!!
