NO SPARK FROM COIL IGNITION LEAD
(In Topic #190056)
Not getting spark but have 12v in coil
So heres what happened unplugged old stereo plugged in new one worked for few seconds then went off now the stereo wont work off ignition live but works fine off perm live so i thought i would seek advice by a friend so went to drive car but now it wont start grrrrrrrr.
Car is turning over when i checked coil for spark there wasnt one from lead to dizzy but i have 12v in the coil my friend checked it with his tester when he fires 12v down lead and i turn key car starts strange it mite not have anything to do with stereo but just seems a cow incidence does anyone on here know what it could be its really bugging me now my mk1 has always started first turn of key
Please someone heeeeeelllllppppppp me
Golf 1993 clipper
Audi A3 S line Quattro
the factory ignition live isnt fused, but if its had an alarm or immobiliser fitted this may tap into it and the stereo could have blown an alarm or immobiliser fuse? either that or the coil has been bodged into some other ignition feed on fusebox. off hand check fuses 17 and 18
Golf 1993 clipper
Golf 1993 clipper
Golf 1993 clipper
Golf 1993 clipper
Golf 1993 clipper
brown haynes manual has the right diagrams tho, i woudl recommend you get one
Incase it didnt work is there a relay in fuse box that controls spark from key ignition switch
All my fuses are good but i guess if its works when he fires 12v down it it cant be a relay because its passing through and firing lol confusion lol
Golf 1993 clipper
if when bypassing the switch and putting 12v down the black wire your car fires then that tells you the switch is bust
Golf 1993 clipper
