Head light switch.
(In Topic #198301)
dash warning lights
- When it fires up ticking over the battery warning light stays on with the oil light flashing.
- Same with headlights on ignition off, no key in barrel.
I've measured charge at the battery terminals when on and it's good so happy that's not an issue. I took photos on strip down, engine bay, when everything worked and it all matches up now.
I'm a kinda stuck now as to what to look at, any suggestions?
the battery light is fed off the blue wire near the battery +, theres a spade plug here where the wire from the alternator pin D+ connects to so check all of that over. if the blue wire is shorted to ground it will bring the battery light on all the time. I'm assuming your battery voltage is showing around 14v when the engine is running yes?
you should only have sidelights with light switch on and key out, check your light switch wiring round the back. the red wire(s) are permanent live and should go to pin 30 on the ignition switch, the black/yellow wire(s) are ignition live and go to pin X
Not looked at the alt wiring yet, no more time today unfortunately.
it should be a 0.3 or 0.24 bar rated switch, OEM VW ones are blue or brown (not black!)
It's probably worth knowing the engine has been fully refurbished with new oil pump etc. This is the first start since its rebuild. The dipstick is showing correct oil level having put 10/40 in, just under 4lt. Before starting I primed the pump turning it over by hand and then fired it up. Could this be part of the problem?
if you pull the coil wiring you can crank it over on starter till it primes up, or if you remove the dizzy you can make some kind of adaptor to run the oil drive off a drill
if you take the switch out and its pretty oily that suggests you have good oil flow at the head, if it comes out dry then possibly not!
