Brown wire fried when slow starting.
(In Topic #195031)
but it's still the same it's as if the battery is low and then the starter speeds up randomly and starts the motor.
But the last time I tried, I had a puff of smoke come from the fuse box and a obvious smell of burning plastic.
soo, I unplugged the fuse box and found this burnt out Brown wire-
Can anyone confirm if this is a earth wire?
It connects to this-
Cheers Darren.
1983 mk1 golf gti campaign
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
2001 Zafira 1.8
2001 Zafira 1.8
Have you any idea where the thicker brown wire goes too Lee?
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
I hope this helps.
Lee
2001 Zafira 1.8
2001 Zafira 1.8
I've cut the thick brown wire out of a doner mk1 cab and joined it to mine and reconnected the smaller one to the earth spade on bulkhead as it was.
Battery charging at mo, so will have another look soon.
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
Can anyone throw up any ideas why I keep burning out this wire please
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
good luck
Lee
2001 Zafira 1.8
2001 Zafira 1.8
Saturday I removed the head light, rad , alt etc loom out of car, stripped off the plastic casing/tape and checked over the wiring and renewed the brown earth and everything was fine.
Then cleaned up the all the terminals , taped up the loom and refitted.
tried starting and it was still the same
Then, took of the earth cable which goes from battery earth to gearbox mount off, it looked pretty clean But sanded the metal down to bare and replaced aaannd It STARTED STRAIGHT UP So the moral of this caper is check the earth cable/strap
Cheers for replying mate
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
http://vincewaldon.com/index.php?option=com_content&task=view&id=29&Itemid=28
So ordered this bush.
It's the main earth for starter motor, so it all makes sense now, as they should be replaced every time you replace the starter.
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
I did the mk2 golf earth mod on my mk1.
Removed and replaced the copper sleeve that sits in the bell housing.
Still the same, ie slow starter.
Thought F-IT and ordered a genuine Bosch starter from local Lucas shop which cost £67 and next day delivery and BOOM it's starts like a new car
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
2001 Zafira 1.8
2001 Zafira 1.8
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
