Cabby roof leak
(In Topic #199638)
Cabby roof leak
Also the mastic that is under the top header seal may need redoing.
Generally tightening the J hooks to close the roof header tighter against the header seal can help.
Cabby roof leak
But I have them in stock anyway for when I'm doing roofs.
For the front header seal apply sillo under the edge of the seal lip where it meets the paintwork across the windscreen frame about 6-7 inches. Start at the very begining outer bit where the seal knuckle is and work towards the middle.
I usualy run a strip of masking tape inline with the seal edge, helps keep clean up to a minimum.
Cabby roof leak
Cabby roof leak
Cabby roof leak
Feel free to come over
Cabby roof leak
If it's a good night we can replace them here if you like. Just bring some silicone sealant with you.
Can you let me know when your available so I can purchase these foam seals from you. I tried re-sealing the outer edge of the top seal, but it still leaks 😕.
Cheers fella
Cabby roof leak
I hope you can help, I have the same problem in my cabbie aswel. is this something you can help with?
I work in in ilkeston, near the old ski slop. so fairly easy to get to….
Cabby roof leak
Sure you can whizz round to me over in Derby if you like.
I can then assess the roof, seals etcetera.
Send me a private message on here though.
