3 door tin top hinges
(In Topic #198986)
My plan is to take the door off and replace the hinges/pins.
Is it worth taking a couple of hinges from a donor rotten door if i can find one (not necessarily rotten) rather than getting the new mk1/2 hinges that have to be drilled out. Or am i flogging a dead horse and should just buy the new ones.
Second question is if buying new apart from opening the hole to accommodate the slightly larger pin is there anything else i should be aware of.
linky for mk2, but mk1 procedure is the same:
http://www.clubgti.com/showthread.php?276948
