vr6 questions
(In Topic #192791)
Brad. said
Mk4's didn't come with a vr?
whats the difference with the v6 4 mo motor then?
use a vr6 or a fwd v5 box with it, and the mk4 inlet and managment job done. I think with the eurowise kit you need shafts? or maybe it comes with?
Old dubs never die, they just get lower
That why the 20v turbo is a popular upgrade as tuned up it's a match for the VR6 and will still return a good MPG.
Just my thoughts…..
I'll keep and eye on your project and good luck with what you chose to have fun with.
Ad.
another option is if you can find a good ratio 02S from mk5 era car you can swap all the internals to a vr6 or v5 gearbox bellhousing. This one is based off the 02J box so it will mount up with 02a/j mounts and shafts (still may need custom ones for vr6 install though depending how you fit it)
