Rainy sunday = mk1 time
(In Topic #201295)
I need to get round to painting my servo but wasn't sure how I could do it in-situ but yours looks great. Did you brush or spray?
cheers mateMossyv6 said
Looks good buddy
I sanded it down smooth using course then going to finer emery paper, then just a bigger bush for the bulk and a little brush to get around the edges etc, I gritted my teeth and went steady but I'd recommend masking the surrounding bits/brake pipes etc up just to avoid making a mess, I moved the expansion tank out of the way made it loads easier just pulls straight up and over to one side minding the hoses
Mossyv6 said
Thanks for that mate, a job to do once the weather picks up a bit
No worries mate, Only other thing is the original sticker I used a really small artists brush to paint around it looks fine although you can buy these for about 2 quid so would maybe recommend buying one and applying this after if you want to make life easier
Also I luckily have a bricked garage at home a gods send with this weather!
Maybe next weekend
It's not as bad as it seems once you get stuck in, a few hours with a multimeter and basic wiring tools and you're away, my topic really helped me could always use this as a how to almostijs1985 said
Need to paint my servo and also need to sort the radio wiring out.
Maybe next weekend
Your car will start and run so much better.
mark1gls said
How old is your dissy cap and HT leads in the first picture? They look really old and grubby, they are meant to replace every 2 years DO IT NOW and buy a new rotor arm!
Yeah it's having the whole lot over winter got all new pulleys and belt too gonna have the alternator refurbished loads of bits and pieces to finish it off might strip down and paint the block whilst I'm there too
