Dan's MK1 20V BUILD
(In Topic #170478)
The Start!
I bought my 1983 Gti about a year ago and enjoyed driving it around standard but always had the intention of going 20v. I got myself a aum engine and 02j gearbox with the full engine and interior harness. Will be going oem ecu with this one.
Here are a few pictures when I got the car.
Then I started to strip the car down to get a better idea of what needs doing at the bodyshop. A few rusty areas but nothing major.
Matt
Been very busy since I started this and haven't had the time to show you what's happening with the build.
Got some new parts mocked up before it went to the body shop.
Now the car has gone to get repaired and painted I started on the engine rebuild.
The Plan is to clean it all up and remove all the emissions cr*p and add a few extras. once I stripped it down I decided to put new pistons in due to having a crack in two of them! Also the valve guides in the cylinder head were shot and so once down to bare block I sent it off to be blasted, cleaned/dipped and machined.
1.8T CABBY
1.8T CABBY
That shifter though
Matt
also - strange question, any idea what bonnet lifters you have? i bought some but they requre the wing being drilled and i'm not doing that.
Olly
I had the hydro clutch pedal box made up by crazy quiffs with the bracket for the dbw. The pedal was from a mk4 golf 1.8t where I got the engine and box from.
And I think the bonnet lifters are jom ones and they come with either threaded or self tap fittings for the wings. I found the self tap ones rubbish and ended up using large washers with the threaded fittings, even then I found them bending the wing so got the bodyshop to plate it under the wing to give it some strength. If I have anymore problems im going back to the old prop.
Picture update coming soon!
Last edit: by dan89
Those crazy quiff pedal boxes are not cheap, but look really well made
Loving that shifter matey. How much did that set you back?
stephen tuite
