Dashboard Main Beam Light
(In Topic #141080)
Well about to start some work on my car and thought I'd better check this out. So does anyone know of the led I need to get? Just wondering if its a special part? Suppose the other question is whether or not to change all the dash illumination lamps as sometimes the right hand side needs a gentle fist on the dash to get it to work!
Any suggestions on this? Do you keep original or try and get it a little brighter??? Defo in two minds as I'm trying to keep the car as original as possible with a couple of slight improvements!
Cheers,
Website Manager
To change the bulb requires the clocks to be split, be extra careful when you do as the plastic circuit boards easily rip and are a pain to repair.
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=34207&highlight=led
Life Member
Dano said
Blimey! That was quick…. I was still looking for the link!!
An old bikers saying Dano " The older I get the faster I was" :wink: :wink:
Good luck with the bulb change Andy I wimped out I'm afraid :redfaced:
Website Manager
