How I refurbished my badges!
A guide to make your badges look spanking!
I have just finished refurbishing my Volkswagen badge and I must say, I am extremely happy with the results!
The reason I have decided to refurbish them is because I can't find a new Golf CL badge, I know I can get new a Volkswagen badge but I thought I would trial run the process on a badge that I can replace if it goes wrong, so I started with the Volkswagen one..
My badges had already been painted with silver nail varnish (don't ask):$ so I needed to remove this first.
I used 1200 grit wet and dry to rub the entire badge, I then used a degreaser (Jizer) to clean up the badge and remove any polish/wax residue. Cotton buds came in handy for this bit.
Using a tack cloth I wiped the entire badge to ensure that there was no dust or dirt on there.
I then gave the badge 5 very thin coats of satin black spray paint so that it looked like this
Once dry I could start the tricky bit, I placed a small piece of sticky backed foil over the first letter and gently, with a cloth, rubbed the foil down so that I could see the letter underneath.
Using a craft knife (I suggest a good quality knife for this bit) I carefully cut around the letter until I could remove the excess foil.
I continued with this method until I had finished all of my badge
I am extremely happy with my results and I will be starting my Golf CL badge tomorrow, once complete I will post a picture up of that badge too.
It has taken a lot of patience which I do not normally have and it was a struggle at times but I managed to get a good technique and after spending 45 minutes doing the first 5 letters it only took me 15 minutes to do the last 5 :thumbs: I'm still thinking about putting clear coat over the top for extra protection so I will let you know what happens if I do this.
Overall it has cost me less than £10.00 and I could probably do another 50 badges before I run out of paint or tape :thumbs:Good luck if your having a crack at this and the best bit of advice I can give is to take your time, give the badge lots of thin coats of paint and don't get stressed if you make a mess with the foil, just rip it off and start again. :lol:
Goly The Golf, a 1983 5dr 1.3cl having a full resto.
Thats excellent mate,great idea & alot of work you put into it :)
I'll send mine over then ; )  Great job!
MK1 Campaign Helios Blue, MK2 Rallye Blue Pearl, MK1 Clipper Cabriolet Black & Corrado VR6 Storm Mystic Blue
where did you get the silver foil from?
Thanks skipper1  :thumbs:
 :lol: My brother wants his doing on his Mk2 Polo saloon first  :P
Hi Shepp,
It is available from Toolstation http://www.toolstation.com/shop/Adhesives+Sealants/Tapes/Aluminium+Foil+Tape+50mm+x+45m/d180/sd2420/p97723 , I'm not sure if you can get it from places like B&Q but I guess they will be more expensive anyway.  :thumbs:
I've started sanding the Golf CL badge and is it sad that I am excited about how it is going to turn out?   O_o
Would you guys put some clear coat over the finished item to make them last longer?
Top work  :thumbs: im going to have to give this a go
This looks fantastic. I was trying to work out how to do something like this and now you have given me the solution. Thank you
Thanks  :thumbs:
I managed to get the CL badge done yesterday! I think I could have made it a little better but I'm just being picky! I'm going to put clear coat over the Volkswagen badge later to see how it looks.
I did exactly the same to mine a few years ago, using the same technique.
I did not clear coat the first attempt and after a while in the elements the aluminium foil showed signs of oxidation.
So I did them all again and clear coated the second time.
Then some brand new genuine badges became available and I just couldn't resist !!
Cheers,
Ade
This is exactly what I will do  :lol:  I'm just struggling to find a Golf CL badge at the min.  :P
Nice job - looks spot on.  :thumbs:
Well done. I also ended up buying new ones.
Cheers Hugh.
Thanks Hugh,
Keep your eyes peeled for a new Golf CL badge for me if you can! I've not managed to find one yet but I'm sure one is out there! :thumbs:
What a great idea and really glad you took the time to share you work. I too will be giving this a go and would prefer to refurb mine rather than buy new just for the satisfaction. I would finish with clear coat to protect the foil.
1985 GL Cabriolet - Long Gone
Several GTI Tintops - Long Gone
Mitsubishi L200 Barbarian 2013 - Daily Workhorse
Thanks ridders , I have given them a spray with clear coat today and I am very happy with the results  :thumbs: They will not be going on Goly until she is out of the bodyshop and I hope that they last a good few years before I need to do them again.
Can you share some photos of the completed badges? It would be good to see the finished standard.
I positioned them on my Golf last night after putting clear coat on, just to see how they looked, so these are the only photos I have at the minute. Please ignore the state of my car, its having a bare shell respray next month so she will be looking spanking by this time next year  :thumbs:
I can second this approach, it's the way I did them a few years back and have just redone them recently.  the movie prop makers love aluminium tape, they use it all the time as it makes things shiny on screen.
I didn't paint the plastic as without etch primer and the right paint it tends to flake off over time, a light sand (800 grit) and a clean with a tack cloth was enough to let the tape stick fast, didn't clear coat and wont be doing it this time either, the tape is designed for use on HVAC ducting, a days curing and it's stuck for a long time.
JackGraceMK1 Just thought I would share this thread so when you get the badge you can make it look like new.  :thumbs:
