What torque for rocker cover ?
(In Topic #189015)
is is there a correct setting for tightening up the rocker cover, as I don't want to over tighten it and damage the rubber gasket ?
Chris
bugs-gti said
10 or 15nm can't think witch lol says in the gaynes
Thanks buddy, I never thought about checking the manual
Because the cork gasket tends to spring inwards, even if you use gasket sealer either side and effectively stick it to the inside of the cam cover it can still spring inwards a little.
They put a tiny dot of superglue on the very edge of it to hold it in position where it sprang in and hey presto, no more leaks!
Life Member
the shoulders on the cork studs and metal rings in the rubber gasket prevent you over-tightening the nuts, though if you go mad you could strip the threads.
also make sure the 2 metal spacer strips are fitted as without them you can warp the rocker cover
